Auto closing windows done with serial VAG-COM!
karaman
128
hi there!
the serial cable bought from hong kong just arrived two days ago,i tried it this morning with vds pro,which i burned on a cd.i created a bootable disc .
as i have just got a laptop with windows 7 64 bit and with no serial port,i bought this item from ebay italy.
http://cgi.ebay.it/ws/eBayISAPI.dll...eName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
the vds pro i downloaded from here:
http://www.filecrop.com/VDS-PRO.html
i have installed the correct drivers and its ok,working fine.
but when i boot from vds pro disc it gives me the following error:
cd-rom device driver for ide(four channels supported).
driver version:v340
device name:banana
no devices found,aborting installation
what is the problem in your point of view?
should i get an old laptop or will it work in dos even if i have got a windows 7 64 bit laptop?
many thankx for replying.
karaman
128
hi!
i purchased an old laptop and i installed ms dos 7.10 on it.
i've already the serial cable and the vds pro software.
i can connect my car ecu through serial cable and vds pro.
but i'm having a small problem,when i press 01 to check my control unit number,it displays me a control unit number but when i redigit 01 the control number displayed changes to an another one and then to another one again,if i continue.
how can i be sure which control unit has it got?
many thankx guys
Feb 26, 2009
5,275
Wolverhampton
Can you post the control unit numbers it is returning?
I don't tend to check the engine number. When you go and check the references that you need to change, they're either the expected values or '0'. It's pretty much expected that the '0' references aren't the applicable ones.
If you read all the references from the memory locations and post them up, you should be able to see which ones look right.
karaman
128
its giving me these one:
!!!C0959799F AY KOMFORTGERBT HLO 0004
!!!C0959801B AY TJRSTEUER.FS KLO 0202
!!!C0959802C AY TJRSTEUER.BF KLO 0202
!!!C0959811A AY TJRSTEUER.HL KLO 0202
the only complete one is:
1C0959812A AY TJRSTEUER.HR KLO 0202
what do you think?
mine is not supported?
my car is seat leon fr mk1 of june 2005!!!!!!!!
5,275
Wolverhampton
It should be supported,as long as it can actually communicate then it should be able to do it. Can you read the memory locations ok?
Yatesy87
Im very interseted in this total open/closure feature but the ms-dos/vagcom stuff is all jargon to me!
anyone with the know-how around the gloucestershire/bristol area fancy havin a go for me?! i drive a 54 plate leon fr tdi
cheers :D
karaman
128
yessssssss we did it.:clap::clap::clap::clap::clap:
the values from 04361, 04362 and 04363 were 10 and i subtracted 8 from them,so,its 2 and it worked.
many thankx SLIMY for the help and patience.
really thankx mate.:)
Feb 26, 2009
5,275
Wolverhampton
Excellent news!! :D I'm glad you got it sorted in the end, it is a bit worrying to start with but by the time you've done it you wonder what all the fuss was about!
