Two jobs I wanted to get out the way today... first was to get the rear crank seal on so that the sump can be fitted (after I have painted it of course)... this needed the engine to be removed from the stand so I could get to the back of the engine...
The rear seal is a complete unit, has a rubber seal around it so no need for sealant and has a plastic guide to aid getting the seals lip over the back of the crank... used a little oil on the crank to help the seal slip on and...
..job done...
Second job was to pack the GT35 CHRA up to send to Dan for its new turbine... this left me with a bit of an issue as I kinda need the turbo to be able to work out space/fitment and of course design for the exhaust mani... as luck would have it there was a suitable substitute
The GT35 on my good friend Tony's pop drag car...
With that 'borrowed' I took a cheeky pic of it next to a K04 which of course id the turbo the old girl rolled out the factory with...
...swapped the hotside over to the Tial for a better idea of fitment... Tony is using a 0.82 T3 housing and looks massive next to the 0.63 Tial... that said, the 0.82 Tial Bill is using isn't that much different to 0.63 in this view... it definitely has more girth to it but both Tial hotsides are physically smaller than the Garrett ones... which is great to help it fit in tight places...
Using a T3 collector Bill had kicking around I worked out a minimum height off the transfer box I could go as I want to sit the turbo low than the normal off the shelf manis do...
After a bit of faffing I have a rough idea of where I would like the turbo to go...
There will be a little tweaking on the bulkhead as the bracket to stand the OE heatshield will need modding to cater for the larger comp housing... I also need to mod the OE heatshield/bracket that bolts to the back of the head for the charge pipe support... this will need a tweak to let me get the comp housing in where I want...
By having the turbo lower and further over towards the gearbox it gives more room to the downpipe to clear stuff it needs to and allows me to manage the heat better... also makes the heater pipes easier to route...
Next stage realistically is to get the merge collector made up as this will dictate a few things in terms of fitment now I have a rough idea... I will also be bolting a block/head onto my gearbox as its sat under the car atm so I can mock up the mani off the car and then offer it up to the block etc in the car to make sure it fits... hopefully will make things a bit clearer once thats done as to where I can actually fit things... haven't tried to fit the wastegate yet... that will most likely be a game changer LOL...
In other news... the star that he is Andrew has got my head ready for pick up so that has been arranged and the head will be with me for the weekend so I can look to get that built Sunday with any luck
<tuffty/>
..job done...
<tuffty/>
