Atp Gt28rs
cupra_matt
Audi Technician
Dec 15, 2004
1,362
Carlisle
iam thinking about getting the ATP GT28RS, but what i would want is around the 300BHP level. I dont want to get into rebuilding gearboxs etc as its mine and my wife to be every day car.
I want the GT28RS for its potential and i like the idea of running at below its max performance. What do you think, RS or X for 300BHP?
Shock_Xe
i reckon our AM04 :p Alot less hassle, Dont underestimate the work involved, We have gone through design on one over the last 2 years, and it is a longer project than we ever imagined, results are awesome but reliability and hassle comes with it and an empty wallet
Nov 2, 2004
9,335
South Wales
I think your gettin confused mate, the GT28RS and the ATP Eliminator GTRS are different trubos. GT28RS will run 350-400 brake and will cost you a lot of money and will blow apart your box and clutch.
Personally i like the power of the GT2X coz its pretty much on the limit of all standard parts of the car and its bolt on. Around 300bhp.
But as mike says above, the AM04 and the JBS04 are all around the 270-300bhp. Which is something i will be lookin at very soon.
MR Ibiza Cupra
185
London
I would say go for the cheaper option. Garrett Turbo chargers are very reliable aslong as there looked after, and if you get some kind of mechanism to control boost you dont need to run your car at 300HP all day every day - you can crank up the boost when needed.
But remember roller bearing turbos are not serviceable if it goes you have to practicly throw it away and buy another one.:p
Shock_Xe
plus i seen some pics of fittment of the gt28rs on stock manni on golf and there is little to no room and looks a bugger to fit, so getting it on an ibiza, seriously doubt it on stock manni/location
As for gt28RS, good luck finding a suitable, proven, reliable, available UK kit on an Ibiza, so far
cupra_matt
Audi Technician
Dec 15, 2004
1,362
Carlisle
Yeah i know there different mate, not getting confused.
Shock-XE tell me more about your AM04 kit please.
Shock_Xe
http://www.seatcupra.net/forums/showthread.php?t=83575
http://www.seatcupra.net/forums/showthread.php?t=81728
cupra_matt
Audi Technician
Dec 15, 2004
1,362
Carlisle
This looks very impressive and very tempting. What does the car drive like? From the graph it looks like it pulls hard right up the rev range.
Apr 28, 2003
2,624
I would forget the rest and get the am04 if your looking for 270-300bhp. I would only use a good mapper someone like jabba. I am sure Mike will point you in the right direction for that.
Most people know what kit i have on my car 60k and original gearbox and clutch. If treated sensibly you can run 300-350bhp without to much hassle. Now having done 18k on IHI and above.
Shock_Xe
MR Ibiza Cupra said:
Shock_XE...... What boost pressure is this car running to acheive these results ?
Does anyone know how much BHP is lost threw the transmission on the Ibiza Cupra:D
I run a little more than nessecery. to achieve 260-275ish bhp 18-20psihold is enough from what jabba said, I run 20-22psi hold but run a large spike of upto 25psi, doesnt affect peak performance just mid range, mods dependant of course
12-15% tranny loss I think
Shock_Xe
drives very well, although torque figure isnt huge (280lbs) it is consistent so decievingly smooth but just keeps going compared to k03 which lets you down after a short while
It does come in hard, had a few people drive it all with positive comments
if u see graph it still has 240bhp @7k+rpm
This dyno was on Jabbas NEW Rollers (old ones are little loser with numbers)
Shock_Xe
thanks Gary,
Agree use Jabba everytime, plus he has a base map for this turbo/mods etc, i.e. mine :) Jabba will also fit the turbo/parts
Shock_Xe
the 4 runs show 2 hot and 2 cold, hot runs being our summer outside temps so know its good for that
Stage 2 should show good gains, Large Port Manni and flown/ported turbine housing and sports actuator
Shock_Xe
Plus the turbo has been fitted and running for 16mths now without issue so has been tested well
JBS Sales
Good Afternoon
Here at JBS Auto Designs we do a conversion kit for the Mk3 Ibiza GT28RS.
At the moment we have a Seat Ibiza Mk3 in the workshop that is having a hybrid GT28RS turbo conversion that has a purpose built right hand drive JBS cast manifold.
With his conversion the power can be taken up to 300bhp without any internal modifications, If you are after more than 300bhp then this can be completed on request, we can offer performance internals so the conversion can be taken up to 400bhp
With this conversion we also manufacture a 3" custom down pipe, centre and rear exhaust system. You will also get a custom front mounted intercooler using high flow core and custom pipe work.
When we have completed this conversion I will post up pictures of the conversion with final power graphs.
P.S. The engine cover will still fit on after the conversion.
EDIT: I have just been informed by Custom-Code HQ that software for all ATP Eliminator turbo kits is now available at Custom-Code agents.
The Custom-Code remaps for the Eliminator kits start from £550+VAT
Mike
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
roll up roll up.... bring it on..
Still intrigued to see how the eliminators get on when they finally hit the uk rollers.
Custom Code Mapping to suit.... :)
OE drive and powerful. Just as it should be.
Going to be an interesting '06 when these start to hit the streets
:D
Apr 28, 2003
2,624
JBS Mike said:
Good Afternoon
Mike
With the kit in question if you have stnd internals is it at the owners risk going above 300bhp or will you just not map it any harder regardless of what they want?.
JBS Sales
We will not make the car produce any more power than 300bhp on standard internals. If the customer wants more power then performance internals are needed.
With putting more than 300bhp on standard internals the engine will not be able to cope with such power and you will be looking at major repair work such as a new block, cylinder head, valves, rods, pistons, turbo etc.
Mike
cupra_matt
Audi Technician
Dec 15, 2004
1,362
Carlisle
Reliability is my main issue as i dont dont have bottomless pockets and ive already spent 3K+ on the car. I would want to make use of the ATP high flow manifold i have on the car so either ATP eliminator or AM04 is the way forward.
I would like the potential to go higher than 300BHP if i wanted too in the future so maybe GT28RS is the route for me, but i hadn't read about the AM04 until now.
Does the AM04 just bolt on or does it require more work than that. I think i have the rest of the hardware required to support a bigger turbo i think? excluding injectors. see sig.
Would these be suitable injectors for both turbo kits? http://cgi.ebay.co.uk/Bosch-803-gre...54667329QQcategoryZ122139QQrdZ1QQcmdZViewItem
