At what HP level does CR need be lowered?
bobby singh
75
Hi all,
The LCR 225 runs a compression ratio of 9.5:1 as standard (which is pretty high) so at what power level does this need to be lowered?
Bobby
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
I dont think it needs to be lowered at all as there are plenty of ihi powered wagons maybe running a stronger gasket buty hardly any thicker.
bill et all will correct me though.
dj_hektik
LEON 20VT FR
if you have detonation problems them a thicker head gasket would help. Plus it would allow you to run a higher boost pressure if your turbo could handle it.
Bear in mind that an increase in head gasket thickness would advance timing on the intake and exhaust cams slightly - this may be a good thing, but work it out just to be safe.
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
Hi all,
Bobby
Pretty sure its 9:1 on 210/225 motors
9.5:1 on 150/180 motors
Mine ran fine on stock CR at 1.6bar boost, VF34 IHI ~340bhp - std factory head gasket
virdi
892
Middlesex
Do any of the Engine Internals need to be changed or uprated at this power level?
Are you still running 340Bhp reliably?
bobby singh
75
Hi - so you are running 340hp on standard CR? has the car been det checked? Are u running pump fuel? Was the car mapped on the road or rolling road?
Sorry for all the questions
Bobby
