At last cheap Cupra R brake discs!!!!
CRAIGLCR
THE DADDY!!!!!
Nov 14, 2005
363
STOKE ON TRENT
mintex pads n ebc discs
ordered myself a set EBC D1338 discs from brakes for you. so will be interesting to see what these perform like with the Mintex extreme pads i have also purchased. free next day delivery and way cheaper than seat!!! will let you all know what i think once fitted and bedded in!!
cheers
225 Cupra R
70
Brake discs front & rear
I am a little confussed to say the least over disc sizes for the LCR (Jan 2004 model) Anyone can tell me what size (mm) disc diameters should be for front and rear and also advise on brand suitability, also which pads would be recommended . many thanks, all advise welcome. :)
Mitchy
TTRS
Oct 12, 2004
2,310
What is there to be confused about:shrug:
British LCR's have always had 323mm up front with 256mm at back :)
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
searchy and all is revealed.
323mm front
256mm vented rear
Ultimax disks grooved and good value, combined with ds2500 pads and you get superb stopping
willbatch
394
Just an update, put 10,000 on this set up now, no problems at all, pads look as if there coming up to half worn which isn't bad for £23! I've been more than happy with this cheap set up and will happily repeat it when i need to.
kwan88
223
Slough
My LCR also needs new disc and pads soon. Can you tell me if on the LCR has the EBC pads caused the disc to have lots of grooves as per the galfer ones?
spikus1969
pads/discs
sounds like EBC are getting better response from users interesting and it does look like Brakes4u have the best prices so i think i know which direction im going on my brake upgrade
smoothuk
SmoothNAV
Aug 26, 2005
589
Essex
I have the DS2500 on EBC grooved and dimpled, and there awesome, just as good as stock brembo disks imo, done a trackday in them and there were no problems at all, they have'nt groved the disks like the OMP pads did to my originals...will buy them again for sure :)
simch
Newbie
Apr 12, 2004
33
Do Tarox do a 323mil disc for an LCR?
Amyone tried them. I have a brembo gt kit on my s3 as the discs keep warping, had them skimmed, warped again! They are brembo drilled versions ...I am looking at alternatives to go with some ds2500s.
willbatch
394
Just another update, have now covered 18,000 miles on this set up with no problems at all!! gonna need another set of pads soon but disks will go again!
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
S3 is too heavy when pounded..
get some ducting to those brakes..
2-piece otherwise req'd I think to shed the heat generated
DS3000's on S3's where LCR's are ok on DS2500's such is the weight factor
simch
Newbie
Apr 12, 2004
33
i went for the ebcs and ds2500 from you, bill and they seem ok on road so far.
ducting is a good idea too.
ryan_s3
1,270
i'm sure my old s3 was suppose to weigh 1415kg while a lcr is 1400kg,so not a massive weight difference??
