That's what I was thinking too Lee but being Stage 2 would the different springs in the Forge be better to adjust the DV.... I'm guessing the APR cannot be adjusted?
That's where my thoughts are at so I'm 50/50 lol!!
Ah thats nice to know it operates with BT builds running big power with no need to swap springs like the forge dvs! What dv did you have previously and is the APR louder or quiter?
Ive run the baileys recirc which would stick when working hard, the 007p which seemed to throw leak codes and needed servicing every 8-10months. The oem valve which seems fine and as said the R1.
They all produce the same volume as its really the cone filter that makes the noise. Without the cone im not sure which would be louder.
If you do opt for the forge use the softest spring you can get away with. The dv needs to react quickly but not abruptly.
I use the SFS Performance Billet recirc DV, and it works great, been on the car 20k+ miles now with no issues and I'm running over 1.5bar boost. It is also cheaper than the Forge
Only went for the SFS because I know David who owns SFS, I was going to go OE when replacing the Forge 007P that was on it when i bought the car, as the Forge constantly got stuck, and just seemed a bit wafty
