Did a couple of logs the other day when SCN was down and using 3rd gear I got 190g/s. Then using 4th gear I got 187g/s both identical runs one after the other
you will get similar results, buy doing it in 4th it will be able to record a lot more data as it will take the car longer to get from 2k rpm to the limiter in 4th than in 3rd.
and thus the more data available the better conclusions you can come to!
i am running boost 8 and still only getting 176.2 g/s but the car flys with no problems, pull back or limp mode what so ever and it is pulling 1.55bar of boost on vag com but settles at 1.45
