Applying vinyl?
ather`s
EXEO Sport & mk2 IBIZA
Sep 7, 2008
2,059
mansfield, notts
if you mean the rear one, i fitted one about 3 months ago. take off the rear reflector panel and seat badge, wash and clean the area then dry it off and then get a bit of string and tie it to the boot lock and put the other end on the boot lid so that it holds the lid at a reasonable height so its easier to work on. offer the vinyl up and make sure it fits. what i did then was to peel all the backing off and lay it into position, then start from one end and rub it with a clean cloth to make it stick properly and to get all the air bubbles out. i got 2 air bubbles that i couldnt get rid of so i got a pin and popped them and they are barely visible now. as i say its the way i did it and it seemed to work for me ok. just take your time and be patient.
suj
Wheel Connoisseur
Jan 1, 2009
5,808
Birmingham
Nice one! I'll give it a go tomorow. Is that reflector easy to come off ?
the "S" for SEAT bit (black backing) if you look at it, it has a screw in it (tilt like how ather`s said) as standard it had a wierd headed bolt, but most have been changed!
when you remove that, then each reflector slides to each side, and voila :)
ather`s
Sep 7, 2008
2,059
mansfield, notts
from seat vince. the part number is on here somewhere. it might be in dinky dave`s thread but dont quote me. failing that im sure if your seat parts man is any good he should be able to find it.
Pander
139
Corby.
www.facebook.com
Cheers for all the help chaps ! heres a link to for all the part numbers for the various vinyls
http://www.seatcupra.net/forums/showpost.php?p=2007869&postcount=12
credit to flapper for that
It went well ! as for that screw that holds the seat badge on, I was thinking aha what they mean is tamperproof torx, but iv never seen anything like that in my life. and it doesnt look like stevie wonder put it on:D
