AP coilovers
DEAN0
Old Git
Feb 1, 2006
5,359
348
Preston - UK
Hi all,
Sorry for the probably simple question but i think i will be purchasing these coilovers in the next couple of months.
http://www.apcoilovers.com/ap_coilover_details.php?id=652
Is there anything else i will need to get them fitted?
Ad
You don't NEED but I would suggest putting new top mounts and bearings in at the same time.
Also has the advantage that you can build the new front units completely and just swap them over on the car.
vroomtshh
4,222
Dreghorn, Scotland
Agreed, and they're so cheap, it would be daft not to.
Off topic, Deano - what suspension mods do you run. You seem to be the first person on here who sounds sensible about suspension :lol:
DEAN0
Old Git
Feb 1, 2006
5,359
348
Preston - UK
On the road car - absolutely standard except corrected camber.
I get my handling fix by playing with the suspension on my Honda Blackbird - haha
Through work I get involved in motorsport - part time for a Dakar rally team and part time for an F3 racing team.
We also sponsor NASCAR in the USA and I have spent quite an amout of time in the NASCAR pits with the mechanics.
Also used to be a rally car navigator (10 years ago)
Ad.
Nice one thanks, where abouts do i get them and do i go standard Seat parts? I wont be fitting them myself so would need to find someone to fit them too if you know anyone in the cambridge/peterborough area?
vroomtshh
4,222
Dreghorn, Scotland
I work for a company that are heavily involved in suspension, but there is no 'real' advice on Mk4 ibiza suspension out there. Thats why I asked. I'm loathe to test enough options for my car due to costs.
Currently its standard apart from poly bushes and adjusted set up (camber, toe etc)
Feb 26, 2009
5,275
Wolverhampton
I don't know whether this will help, but the Toledo version that I'm looking at is £372.81 on the AP website, DPM performance offered me a price of £301.70 inc VAT and delivery. Might be worth dropping them a line...
DEAN0
Old Git
Feb 1, 2006
5,359
348
Preston - UK
If I was going to play with the Ibiza - I would probably go the same way I went with the Nova GTE.
Koni top adjustable dampers and -30mm Eibach springs.
The koni's are old school non gas dampers but they have a concistency that I like in suspension.
-30mm is enough not to trash the ride quality or throw the geometry way out.
Thinking about it - I would probably look for a set of OEM cupra springs to go on my 130 TDi Sport
and add the top adjustable koni's
Apr 27, 2008
900
Hi all,
Ad
those arre the wrong coilovers mate, you need 6L http://www.apcoilovers.com/ap_coilover_details.php?id=653 ;)
when i fitted mine i changed the top mounts and bearing too, got mine from SERE MOTORS for £40 (only need front two as backs don't need them) i also got new standard drop links which were about £20 as my old ones where knocking. you don't need shorter drop links like you do with other brands like v-maxx.
theres a great bit of kit mate, you want be disappoined :)
Ad.
Yeh i noticed that after contacting DPM, thanks for all your help guys, i shall pop into my local dealers and get all the bits you mentioned and get them fitted the same time as the coilovers go on. Do i need to prep them at all to stop rusting/seizing?
Apr 27, 2008
900
put loads of copper grease on them, it does a great job. when i put my new brake disc's on the other day, the coilovers were filthy but when you run your finger over where you have put the copper grease they look brand new. i haven't got the adjuster cup on the back because i wanted them as long as possible but if your keep them on, put loads on them too
