Anyone Running the APR maps on cruise control?
ChrisGTL
'Awesome' LCR225
Nov 17, 2007
2,459
Huddersfield
As above, I'm just trying to make sure i'm following the correct proceedure to activate the different stock/95/97 maps.
- Turn key to ignition position (engine not running)
- Keep 'set' pressed on cruise stalk
- Wait for the engine mgmt light to flash (1 flash for stock map / 2 flash for 95 map / 3 flash for 97 map / 4 flash for valet mode)
- Release 'set' when correct number of flashes
- Wait 5 seconds
- Turn key to off position and wait 5 seconds
- Turn key to ignition and wait 5 seconds
- Start engine
Is this correct?
Also, is there any way of knowing which map the car is using via VAGCOM? Apart from running logs and working out the MAF/MAP readings?
Just done a log for the 1st time since having the APR on;
MAF is reading 171g/s @ 5400RPM
MAP is reading 2190mbar @ 3920RPM
MAF reading looks pathetic, not sure about the MAP reading for a stage 1 LCR 225 though??
ChrisGTL
'Awesome' LCR225
Nov 17, 2007
2,459
Huddersfield
ChrisGTL
'Awesome' LCR225
Nov 17, 2007
2,459
Huddersfield
oh, I was told to wait 5 seconds, the PDF tells me to wait 10 seconds minimum and do 2 cycles between ignition on & off.
Is the LCR a 'DirectPort Programmed' car? lol
JPS1
Cupra Of Death!!!
Nov 12, 2009
47
Stoke On Trent
yeah the LCR is a direct port programmed car. i'm also running a jetex, 007p & silicon tip. Sorry i can't be any help with the logs mate, although i would be intrested in getting mine done just to see what i g/s i'm getting
