Anyone know where the ABS pump module is?
sialdo
79
Chester
As I have the stupid traction “01435 Brake Pressure Sensor 1 (G201)” fault, I may need to take this off and get it sent for a recondition. Is it easy to get too and take off?
I did have a look under the engine bay but couldn't see anything that may resemble this part!
:help:
Dangerous Dave
50
It is at the back of the engine bay. Fairly easy to remove I assume you are going to send the pump to http://www.ecutesting.com/seat_toledo___leon___skoda_oct.html
Instructions for removal :-
WI-XML
Special tools and workshop equipment required t Torque wrench -V.A.G 1331- t Torque wrench -V.A.G 1410- t Brake pedal depressor -V.A.G 1869/2-
Sealing plugs repair kit, Part No. 1H0 698 311 A The transport protection for the valve contact pin must always be placed on the hydraulic unit after the control unit has been disconnected from the hydraulic unit. No guarantee will be recognised for hydraulic units without transport protection.
1 - Transport protection for valve contact pin (foam)
2 - Sealing plugs M 10
3 - Sealing plugs M 12 Removing Location: Control unit is bolted to hydraulic unit and is located on right in engine compartment.
WARNING
Do not bend the brake lines in the area of the hydraulic unit! – Read out and note the existing control unit code. – Note or request radio code on vehicles with coded radio if necessary. –
Disconnect battery
– Remove engine cover. 1.9l diesel engine:
– Remove connecting hose to intake pipe
– Remove intake manifold flap motor V157
2.0l diesel engine: – Touran vehicles only: Remove plenum chamber middle bulkhead
– Remove connecting pipe between intake hose and turbocharger.
– Remove toothed belt guard upper part.
Continuation for all vehicles:
– Release connector on control unit in direction of arrow -1- and pull off
-2-. – Fit brake pedal depressor -V.A.G 1869/2-.
– Connect bleeder bottle hose to front left brake caliper bleed valve and rear left brake caliper bleed valve and open bleed valves.
– Depress brake pedal at least 60 mm using brake pedal depressor -V.A.G 1869/2-.
– Close front left and rear left bleed valve. –
Do not remove brake pedal depressor -V.A.G 1869/2-.
– Place sufficient lint-free cloths under the control unit and hydraulic unit.
Ensure no brake fluid gets onto contacts.
– First identify the two brake master cylinder brake lines -A and B- and unscrew from the hydraulic unit.
– Immediately seal brake lines and threaded holes with seal plugs from repair set Part No. 1H0 698 311 A.
– Identify brake lines (brake calipers) -1 to 4-, unscrew and seal.
– Pull hydraulic unit with control unit upwards out of dampers.
sialdo
79
Chester
Thanks for instructions D Dave.
Wil be ecu testing or BBA-reman.
I will defo get this done before winter is upon us.
techie
Skoda Techie
Mar 22, 2003
5,438
Worcs
You will need pressure bleeding and diag equipment to refit and set up even if the pressure sensor is replaced.
sialdo
79
Chester
Thanks, I asked at local vag specialist to me. £55 per hour (2 hours) and £30 to do whatever it is on vag com.
So is going to be around 500 mark for a known error :(
sialdo
79
Chester
I have my own vag com software and Hoping to re code it myself. Is there anywhere to find a thread already on this?
Do I have to write the codes down before removing the part or something?!
techie
Skoda Techie
Mar 22, 2003
5,438
Worcs
its not the coding thats the easy bit. You need to -
Calibrake brake pressure sensor
Calibrate longitudinal sensor
Calibrate lateral sensor
Calibrate J500 steering ecu
Calibrate G85 steering angle sensor
The last two might do themselves on a road test, might not.
If you are using a new unit they come prebled and vented now. So all you need to do before you undo anything wedge something inbetween the front of the drivers seat and the pedal to keep a bit of pressure on it. Undo the pipes onto the unit and very little fluid will come out, swap the unit over and connect up. The remove the bar and carry out a regular brake bleed. That should be fine, no need for the 17 cycle ABS bleed with diagnostics.
sialdo
79
Chester
Hmmmm I'm not that too techie so might get inde garage to do it. Better safe than sorry. Thanks for your imput though :)
sialdo
79
Chester
I bought a recon unit off eBay. Got a inde to fit and he tried to code it in but wouldn't allow it!
Had to take it to Seat Liverpool in the end where it took them 2.5 hours to do as they had to do 18 different codes or something?!
All sorted now though.
