Hi,
I'm thinking of buying a system for my car that helps with cooling - the theory seems good ... I'm just worried about quality and safety issues.
It's called the DEI CryO2, The website says:
http://www.designengineering.com/products.asp?m=sc&cid=1
It seems an easier alternative to installing a FMIC for now, and when I do install an FMIC later it will perform even better.
Im worried about having a pressurised tank of CO2 in my car, though. I know its not a volatile gas but the pressure is - plus I park my car outside in temps of 50 degrees centigrade plus... but that temperature is the same thing that has such a huge impact on performance ...
I'm thinking of getting the intercooler sprayer and intake cooler. Also I might get the heat resistent wrap for the CAI pipe and metal IC pipes so they dont store so much heat...
I recently found a good motorsports parts supplier in Dubai so a long problem I have of shipping parts from US or UK (expensive .. duh!) is practically solved, their prices are OK and they sell a wide range of products I would otherwise have bought online (http://www.mstorque.com)
They also are dealers for Sparco, Speedline, H&R and others ... mmmmmmm
The CryO² is a revolutionary new, award wining product designed to reduce the temperature of the air/fuel intake charge thus creating power. Through the science of aerodynamics and cryogenics, Design Engineering has developed a system to harness the cryogenic properties of liquid Co² to lower the air/fuel intake charge by up to 60%.
