Any 1 know much about error codes ???
math-30
63
this is just an add on to a past thread i put on here ....
http://www.seatcupra.net/forums/showthread.php?t=155810
i have put a scanner on the car and it braught up the following .....
Fault code (P0234) Engine boost condition - Limit exceeded
does anybody know what this could mean or the cause of it ???
brief descriptin of symptoms :- initially seemd like the turbo cuts out at 100mph in 4th gear. but now have realised it is inconsistant at what speed or revs it cuts out but allways has happend in 4th gear (this could just happen to be a coinsidance)
for full detail on what was happening click on the above link
many thanks Math
Mar 26, 2007
2,020
S.Wales
As as a guess I would say it is overboosting, faulty n75 perhaps?
Maybe someone who knows alot more than me can give a better answer. Wheres DPJ when you need him.... :)
math-30
63
yer at a gess i would say that the preasure is getting to high in the turbo but dnt know how that could be happening
Stan 24v
421
Blackpool
http://wiki.ross-tech.com/index.php/16618/P0234/000564
16618/P0234/000564 - Boost Pressure Regulation: Limit Exceeded (Overboost Condition)
Possible Symptoms
* Boost pressure too high
* Reduced power output
Possible Causes
* Hoses incorrect connected, disconnected, blocked or leaking
* Malfunction N75
Possible Solutions
* Check charge pressure control
* Check Solenoid Valve for Boost Pressure Control (N75)
frenchy
TPS
Apr 23, 2007
228
Swindon
If its not boost leak or that valve I would say its the variable vanes on the turbo sticking they need cleaning. Not an easy job but there is a kit available that will clean it out. My sisters golf pd 150 does it now and again.
majmir
Cheers Frenchy.... ive just bought a boost pressure sensor cos got told thats a common fault on the PD engine... will keep you posted.
majmir
Aye up fellas.... replaced the boost pressure sensor and wahey, cars running sweet again!!!..... BUT my joy was short lived, the boost pipe on the underside of the lump popped off so reckon it was the sensor and the pipe that was the problem... any ideas as to how i can keep this boost pipe from popping off?? Thought of a jubilee clip but thats a bit tacky.
