Well i have been doing the searches and seems that peeps have had issues with their LCR after remaps and in cold (5*C or lower air temps) starts.
I get the 17705 code on vag com. This Never ever did this when LCR was standard. I have tried different DV and checked pipes, TIP and IC pipes for leaks. The MAF give good values, (190g/s running peak 1.25bar) and I have seen some have blamed the Intake Air Temp values in the Audi Code for the LCR. I have informed my mappers and they are coming to see me tomorrow to try it.
Has anyone else who has had this and found a solution? Help even if i drive like a granny on cold start it still hits limp.
If the engine has the slightest bit of heat in it, it is fine!
