Amplifier
Guinness
Finally got the BMW
Nov 29, 2006
4,422
Newcastle
Thinking about getting an amplifier to run the speakers in the car. Wondering what the best way to do this is, dont think I will have a problem wiring the actual ground and power, but wiring the speakers up might be a problem. I am a total nub when it comes to this so any help much appreciated.
THe maing things I need to know are how to wire the amp in, what amp to get, what channel amplifier I need (2,4 etc).
O I am runing standerd tweaters and 4 sony 160w(peak) speakers
Ric 2001
Need an ID-ten-T form
I'm running 4 speaker of a 2 channel amp. Now there is a bit of math required.
http://www.alphacaraudio.co.uk/View...e P3002 - 300W x 1 @ 4 Ohms RMS mono&Search=Y
That's the amp. Now if I run 1 speaker off the left channel, and that speaker is 4 ohms then the amp will out put 100watts on that left channel. But if I put 2 speakers on the left channel and run them in parallel this will give a 2ohm independance: Total ohms = 1st speaker ohms x 2nd speaker ohms / 1st speaker ohms + 2nd speaker ohms. total = (4x4)/(4+4) = 16/8 = 2ohms
Therefore the amp will now be 2 ohms stable and produce 150 instead of 100watts.
This site has a good picture for the differance between parellel wiring and serial. http://www.bcae1.com/srsparll.htm
A concern regarding speaker impedance involves mixing speakers with different impedance ratings. Avoid doing this, because drivers with different impedances will "see" different amounts of power
And last but not least, pay attention to polarity while you're wiring up your masterpiece. Make sure each driver is correctly wired – positive amp terminal to positive speaker terminal, and so on – or cancellation problems will conspire to drive you nuts.
Just remember even the most complex wiring schemes can be reduced to a simple sketch
bellamy06
62
a good website to look at prices and models.... www.caraudiosecurity.com.
if youre only running two speakers then buy a 2 channel amp, if youre going all out and going 4 speakers then buy a 4 channel amp.
wiring is simple really,
do your power supply and your earth, then run the RCA's from your headunit to the amp.
now wire your speaker wire from the terminals on the amp to your speakers.
i did mine a while ago now (about a year) its so much easier when you have it all in front of you, its so simple
cheers. tom
Guinness
Finally got the BMW
Nov 29, 2006
4,422
Newcastle
ah right so I would have to rewire the speakers, ie so they arnt wired into the headunit. New wires etc?
I always figured I would intercept the speakers at the headunit or something.
bellamy06
62
standard seaker wire is straight to the factory headunit with doorbell wire as speaker wire!!!
if youre doing a proper job of it buy an aftermaket headunit, an amp, some high quality RCA's and some decent speaker wire.
i put my amp under my seat so it was close to the front! didnt need long RCA's or much speaker wire that way.
tom
Guinness
Finally got the BMW
Nov 29, 2006
4,422
Newcastle
I have changed the headunit and changed the speakers with component sony speakers just joining the original wiring in. Anwyay am sure it will be clear or I may even pay someone to do it lol get my moneys worth though..
Ric 2001
All it's a complete myth that you have to have the same amount of channels to the same amount of speakers. I've seen 10 speakers on a 2 channel amp. Just as long as you don't drop the ohms below the recommended ohms ie if you drop the ohms to 1 then hope you like pyrotechnics. Just all about wiring and ohms of the speakers!!!
Ric 2001
