Amping my comps
Nutkin
Pop-a-Keg ya?
Aug 24, 2006
2,581
Schnaitsee
Right i fitted my comps and they sound good but distort at what i dont consider to be loud enough ;)
So i wish to amp them up.
I have two sets of 16.5cm Rockford fosgate Comps in the doors and i plan on getting a JBL 4 channel amp as i have limited funds and heard these to be very very good value for money.
My question.
How do i wire this up, Anyone got a good place to stick the amp and how do i get the wires into the doors... especially the drivers door as i figure the amp has to sit in the footwell on the passengers side or something. ??
anyone done this and have a few pics they could send me. Im a bit useless without diagrams but if you could explain it well please do :)
UncleFester
Grumpier by the day!
Apr 30, 2006
4,764
Milton Keynes
www.facebook.com
Replacing Leon speaker cable with new stuff.
This is meant to be a brief guide but hopefully it will let you know how easy this job is.
What to remove;
Front door cards - pop the handle cover off ( large flat blade screwdriver does the trick here ) Undo the two screws inside this that hold the door handle to the door and remove the two torx bolts from the bottom of the door. Gently pull the door card away from the door and pop the clips off - you may snap these if you don't pull straight. Once that's done, lift the door card up and it comes away. Unplug the tweeters, electric windows, mirrors, courtesy light and unclip the door handle cable holder and remove the cable hook from the door handle.
Rear doors is identical except there are no torx bolts.
Trim between the doors at the bottom of the B pillar. Just pull this away from the pillar and it will unclip and lift up and out.
Bonnet catch:
Two screws hold this in place, undo them both and let it hang loose.
Front footwell covers:
Remove both of these carefully, they're held in with clips on the passenger side and two plastic bolts on the drivers side. You may lose a clip or two, but they can be pulled out with pliers.
Bottom trim along the sills:
Once the footwell covers are out you can remove this. There is one screw holding each side in next to the seatbelt mechanism just behind the drivers and passenger seat. Lift the rear set forward and undo the rotating plastic screw / washer that holds it in place. Get someone to lift the whole piece from the front so you can slide it out from under the rear plastic cover that it links to. Again the trim clips may come loose, they can be removed from the car with pliers and refitted to the trim strip.
Removing the factory speaker holders:
Drill the rivets out with a large drill till the tops come off, then lever the speaker holder away from the door till it pops off. Drill the remaining metal of the rivets out.
Cable Run into front doors
Drivers Door;
Unclip the rubber grommet between the door and car, remove the plastic holders at each end and take care NOT to let them fall into the hole. Refix them to the rubber grommet. Cut a hole in the grommet that seals the existing cable through the door, feed your cable in and reseal with tape. When you put the new cable into the hole, there is a plastic guide that will ensure your wire comes out where the grommet hole is. Run it through the grommet and down into the car body, it will appear through a hole in the metal where it can be pulled through exiting just below the area that the bonnet release attaches to.
Passenger door;
Same as the drivers door excep the location where you need to pull the cable from is packed with foam in a plastic bag, half remove this and the cable will appear.
Rear Doors
Both are the same however there is no cable guide but if you have long slim fingers you can pass the cable through and reach it. Repeat the same process with the grommet and its two clips from the door to the car - don't want to lose them inside the door or the car. Run the cable over the top of the factory fitted plastic plug and with a bit of wiggling the cable will appear just above the seatbelt mechanism. Make sure you run the cable behind this and away from any moving seat belt parts!
Fitting is a simple case of reversing the removal process - take real care with the door card clips as they like to jump out and roll away and are definitely on the fragile side. Expect to lose one clip on the drivers side footwell card as it's a really tight awkward fit.
Why bother ... well when you sell the car and you want to fit the old speakers back in, it's easy to do because all the old wiring is there and hasn't been hacked up, plus the factory fit cable is not suited for amplified speakers as it's really cheap and thin.
Hope that's useful to someone
Nutkin
Pop-a-Keg ya?
Aug 24, 2006
2,581
Schnaitsee
does the wire to the drivers side go under the steering column or something??
i can see this involving alot of tape etc and some wooly stuff to stop rattles. :(
But thanks man thats very useful guide. When i get round to this ill take some pics to go with it.
Im so annoyed there is no haynes manual for the leon.
UncleFester
Apr 30, 2006
4,764
Milton Keynes
www.facebook.com
There's pics on my car thread ... but they won't help much with disassembly.
The amps in mine are in the boot. Wires run from the boot under the back seat where they split, one pair goes up the drivers side and one pair goes up the passenger side where they split into each door.
The RCA cables and amp power cables run down the centre console, out under the drivers seat, up into the sill area and then up under the back seats.
There's quite a lot of cable and not a huge amount of room but it's tidy and it fits.
