Ambiant door lighting fault
Jul 23, 2024
Hi I've newly bought a seat leon hybrid 2021. Yesterday while parked up the passengers door ambient lighting (under door handle) flickered a few times and went out, since then it's not came back on. Does any one know if this would be a fuse or a electrical problem? what should I do next to fix this?
Cainy1989
93
40
its not going to be fused unfortunately, it could be an issue with the door module or failed LED - you could try disconnecting the battery to see if that helps, failing that you'd need to get codes read from the car to see what it thinks is wrong
KoNG
528
115
London
Most likely, the module has failed and needs replacement. It's better to do it yourself, as the dealership would charge you a fortune since all doors need to be taken apart.
