Alternator.
CraigW
Craig.
Apr 12, 2007
4,607
Hawick, Scottish Borders, Scotland
How easy is it to change the alternator on these cars??
Im needing a new one as the bearings in mine are f:censored:d so they are whining etc. The alternator is still charging the battery though.
Also does anyone know where I will get a re-conditioned alternator from.
Am I right in thinking that its a 70amp alternator I need? Engine code is APQ
Thanks,
Craig.
captin_urbis
Not a Member
Dec 2, 2008
452
Lancashire
i dont think its that hard, take off the fan belt then all plugs and just unbolt it, got a haynes manual? should have hints and tips in, if not then will photo copy it for ya
as for the recon i havent a clue. soory bout that
caddyrage
Nurburgringer!
Jun 26, 2008
95
Ellington, cambs
Yes the alternator in the ebay link will fit. I'd know because its mine lol
I take it your ibiza 1.4 has power steering?
if yes then it will definately work.
None power steered polo mk4 and mk2 ibiza have a different casing so they can be adjusted.
On power steered models, theres a seperate pulley to tension the belt :)
CraigW
Craig.
Apr 12, 2007
4,607
Ive managed to pick up an alternator locally from an apq engine coded car.
So it should be easy enough to change on my own?? and I dont have to worry about the belt tension??
Want to try and gather as much info about it before I decide to change it. Dont get me wrong, I know how to use a spanner etc as Ive done maintenance units as part of my engineering apprenticeship, I just want to find out as much as possible before I do the change.
