alternator whine
Mckellar
I've had 2 ibizas now, one at 25k and my gti at 55k miles and both have had this sort of whining noise, sounds like an alternator bearing perhaps?
anyone had this problem.
Its not a belt because they have only been replaced approx. 5k miles ago.
Thanks, David.
Wallis22
282
I have the problem on my Toledo. Been told by the AA it's a common fault on the TDI, but not sure if he meant petrol models aswell, he just said it's a common fault. He also said it will work for a few more months but will then pack up without warning.
Mckellar
did he say what the noise was, am i correct in saying a bearing?
Wallis22
282
Sadly, i can't remember what he said it was. It was def' not the belt though. Don't know if that helps. I'm no expert on these things but, yes, worn bearings sounds the most likely cause. Someone with more knowledge will be able to confirm this though...
Mckellar
cambelt has pretty much 'just been done'
better not ping on me *touches wood*
pooch
Clueless
Jan 12, 2003
78
West Cuntry
whining from the alternator is almost definitely the bearings, it's a sign of wear on the inner or outer race.
If you can get them out the bearings are very cheap to replace, there is generally a serial number on them which you can use to order new ones.
beezertart
**MAYHEM**
Sep 11, 2007
1,260
beyond the sun
Thanks, David.
ooh,hope you're not about to get a run of niggles as well!!irritating and piggin expensive:cry:
Kai_1600
Shallow
Dec 10, 2005
410
Manchester
My mate had an interesting way of eliminating belts from an equation, he just chucked a tiny bit of talc powder on the belts and if that stopped the squeaking then they were what was causing it.
