Sol
Hi all,
Just had my car back and found that the cd changer decided it didn't want to work so decided to get a new headunit.
I went for the Alpine unit as you don't need to have a car full of discs as it works off USB and iPod only. Installed ok, but found that the EQ settings were resetting to zero and also the radio stations would disappear after the ignition was turned off and the key taken out.
I want to know if any one on here has had the same problem? I'm going to check tomorrow if I have 12volt coming in on the main yellow wire on the harness and also check that the inline fuse on the on the harness to the unit hasn't blown either. It runs fine off of the ignition wire but everything goes after a couple of mins after the unit has discharged.
Also, before the new unit went in, the original Aura ran fine for a few days then would not turn on at all. Would this lead to whats happening here.
Will add anything if I find the problem.
Cheers all
Cheers all
