Just found these clicky They look to be the same as the Carmodshop ones that are out of stock? Anyone know if they work?
These are marked as reversing bulbs, I guess they will be OK as sidelights?
Sidelights (501/w5w type)
These were relatively easy. You can buy 'canbus compatible' LEDs of many flavours now, but I still had some plug'n'play resistor cables that I took from my FR when I sold it, so I've used those in my Ecomotive, together with some Philips 4000K LED 501s. They are a decent match for the bi-xenons. Maybe a tad warmer white but close in colour, and importantly they don't have that obviously-after-market look and make the reflector blue when they're switched off like the 501 bulbs with blue glass do.
Yes (or get 'canbus friendly' ones with the resistors built-in).Do you need resistor cables in Leon 2009 FL ?
I've just been trying to view the alternative canbus-compatible 382 module from ultraleds.co.uk (as linked by Nath above) but it's showing page not found so I guess they're also out of stock now...
If anyone is still having trouble sourcing some white canbus-compatible LED replacements for their facelift DRLs (382/1156 bulb type), I just found these:
http://www.car-mod-shop.co.uk/Canbus white 27 SMD LED BA15s 1156 382 bulbs
They look similar to the ones that I have, but these new ones also have 3 SMDs pointing forwards as well as those mounted on the double-sided crossed PCBs. Might be worth a shot?
