alarm horn not working
hungabunga
232
Tried to enable alarm beeps and found out that my alarm horn is faulty, where is the alarm horn located. Read conflicting info so could be behind drivers wheel archer liner or on bulk head in engine bay under the cowling
Vagcom error below
1 Fault Found:
01134 - Alarm Horn (H12)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 233
Mileage: 103245 km
Time Indication: 0
Date: 2097.14.11
Time: 16:20:46
sully
hungabunga
232
i have had a quick look through but couldn't see anything. it would be great if you could check.
hungabunga
232
Hi Pal
Unfortunately the car is out of warranty due to the mileage but as it is only just they are trying to get Seat to sort it as a goodwill gesture.
The above post is correct as I asked one of the engineers, to put any potential thief's off it is encased in a metal box and it will deafen you before you get anywhere near it.
Sully
Nov 1, 2008
559
birmingham
Hi Pal
Sully
Did you get this sorted mate ? Was it the siren that was broken
hungabunga
232
Hi Pal
I am still waiting on Seat UK to respond on a good will gesture. The part is £115ish when I asked the dealer so hopefully it will get covered under warranty.
I will most likely take a look myself at the weekend so will post back then.
Sully
Jun 30, 2021
Hey newbie with my SEAT Leon mk2 I’ve found exactly the same problem, located and replaced the siren and still no joy.. also vagcom vcds told me the climate control has been messed (after changing the stereo) and he managed to reset the code for that but had the same code (H12) no communication to the siren. Could this be the CCM? Stumped and following …
Jun 30, 2021
I’ve recent had a problem with my alarm siren (no chirp or sound at all) successfully located it and replaced it to no avail. Next I Opened the siren horn and found the internal battery was dead. managed to replace the 3.6v internal lithium battery inside the siren and for a few weeks had my chirp back.. since then it had died again which tells me there’s no charge going to the siren battery but is receiving signal.. has anyone got the alarm wiring diagram so I can locate a possible inline fuse that’s not on either main fuse board?.. thanks
SWANSWAY CUPRA Dealership
