alarm help/location
cupra_poolie
93
Hartlepool
Im having trouble with my alarm the last few days. It keeps randomly going off. At firast i thought it was the neighbours cat sleeping under my warm exhaust but it isnt. Anyone else had trouble like this before?
Also where is the alarm located? it went off at 4am today and wasnt impressed, just disconnected the abttery half asleep ha. Need to get it sorted so was going to disconnect alarm for the time being
thanks
mark1231
146
The anti-theft alarm monitors the access
through the doors, bonnet and boot and the
activation of the signal “15” in the ignition
switch, and it is governed by the central control
unit.the unit is behind trim on drivers side it sets
off the horn behind front bumper you may find one
of the doors are showin open when shut setting off the alarm
scan with vag the comfort system channel 1 to see if all doors
are shut
cupra_poolie
93
Hartlepool
so is there a way to turn off the alarm without taking trim etc off. I cantbe havingit going off work all day 2moro.
im taking it to the garage as its got a warranty still but need a quick solution asap
dirty
The usual cause for these are the boot lid sensor's failing causing the alarm to trigger
