Air Con Re-Gassed....But Still Not working....
CupraBabe14
52
Brighton
seriously having no luck with my car lately....
Took it into Kwik fit today as got the air con re gassed and also de bugged....
picked it up and the guy there told me its not working :( he did a diagnostic test said it cam up with a fault....
then he realised he pressed wrong button on the heater and then had it set to air con but it still dont work:confused:
he said theres no leaks and all fine just dont work and they cant repair it there
the diagnostic then came up with no fault but still no air con :(
he said it might be a fuse or electrical fault??? any ideas people:blink:
full refund from kwik fit which was good but just need to see where the fault is
Any help appreciated :D:D:D
juneau
114
Midlands
The biggest problem in this scenario is that you took it to kwik fit. Those guys know sod all and will have you replace the whole car to fix a squeaky wiper blade if they had their way. Wish I could be more of a help but good luck mate
big rich
VAG techie
Apr 22, 2011
487
south yorkshire
they should of checked for faults and operation of the aircon before regassing it. As above really don't ever take your car to kwik fit, not even for a free MOT like i did. most common fault in my experience if theres plenty of gas in it, is the high pressure switch, find a decent garage that specializes in vag's.
big rich
VAG techie
Apr 22, 2011
487
south yorkshire
its a switch on the air con which reads pressure/temp of the refrigerant if its faulty it will cause the air con to not work and sometimes blows a fuse. Although there are other things it could be. look at end of dash behind cover for fuses (drivers side).
hedgehog-harvey
58
Mines also stopped this afternoon :( can't hear the compressor fire up. Looked in the manual but can't see what fuse it would be
Marshall
3,256
Bonnie Scotland
From memory when the compressor clutch goes faulty you get a pressure sensor error due to the compressor not creating pressure.
When mine was done under warranty they replaced the pressure switch first but made no difference.
The new compressors have a different pulley setup which is much more reliable.
Have a search for aircon compressor failure on mk2 Leon and from the pictures you'll know which type you have
Although yours could be low on refrigerant or something else
CupraBabe14
52
Brighton
hi there
i work at tps and i have been sellin lots of pressure sensors in the last fewd weeks i would bet it will be that
How much are the compressor sensors??
It sounds like it fires up but just blows out hot air!!
Dad is gona take a look tmrw as was too late earlier and I really haven't got a clue what I'm looking for??!!
Mine is 07 about 30k on the clock!! X
Rob66
1,626
95
UK
Yesp, High Pressure Switch thats what was wrong with mine, about £130 fitted by the dealer including a regas last month.
sam7
Find an Aircon Specialist. I know so many Dealers and Garages (inc me) that sub out to a specialist. I have wasted hours myself trying to regas vehicles and trace faults to call in a specialist and they find it in minutes because thats all they do!!
Above all it is sooo nice to turn on your Air con and it is Icy cold and smells clean and fresh
tonto
1,265
plymouth
tried mine today to find it wouldnt get cold... ffs.
the fan kicks into over drive, and i think there is a leak from the switch too! ffs.
ill try regassing it in work tomorrow and seeing what happens next.
Kaza
Female Petrolhead :)
Jul 5, 2010
1,208
Kent
I found out my air con wasn't working after SEAT checked the compressor and it turns out a part of it snapped off (the clutch part they called it). Could be another reason?
The early MK2's aren't good at all. Nothing but issues with mine such fuel pump, cam follower, cam shaft, air con, coilpacks. All common problems SEAT know about, yet wont do a lot to help?
big rich
VAG techie
Apr 22, 2011
487
south yorkshire
There should always be pressure in the system, when the cars not running i look for circa 5 bar +, although just because it has good pressure doesn't mean there's sufficient refrigerant in it.
tonto
1,265
plymouth
luckily ill do any repair work myself and get the parts on trade! but its hassle knowing that its "common" problems and the dealers take it to their advantage of making money from it! certainly when you know how little it costs at times!
im hoping it just a case of a new swtich and a regass which will be of minimal costs to myself.
ill check the system tomorrow, for leaks. pressure and gas levels and worry about getting parts in on monday if needs be as its my only day off for a while then!
im sure though when i first got the car, put the air con on the fan (engine / rad fan) did not kick in, or if it did it didnt go crazy like it does now! it drones out the radio in the cabin! fml.
