pickie
222
hi all my air con gave up the ghost today :( the little AC light on the screen shows but no cold air, just the normal outside air temp :(
1) could this be due to it running out of coolent gas ??? as the car is now 4 years old and never be charged ??
2) is it fooked ?
cheers
pickie
If it's anything like mine check the 30a fuse on the right side of the fuse box on top of your battery. Won't be blown but I get dry connections there quite often. Clean and re-seat the fuse, hopefully that will sort it. You will probably find it is stuck in quite stiff. Just give it a good yank with some pliers.:D
ok if the fuse dont help my air con im going to go and get a diy regas kit
?? where is the air con refill nipple on the car Ibiza MK3 ??????
get it regased properly its only about £50 sqiud plus the old gas has got to be disposed of properly!
o and the gas is dangerous
Rick-24 said:
could be your outside temp sensor, have u read wat temp its showing latey?
I've noticed that on mine recently e.g. 3pm yesterday it was showing 12 degree when it was showing 29degree in a car next to me. Where is the sensor located any ideas.
Under the passenger wing mirror. You'll see a little black thing sticking out, take the back plate off the wing mirror andput a new one in
£20 or so from seat
