Just to set my mind at ease lads. I have a leon cupra but have the Koni FSD's fitted which have the ARB mounting points on. So this would mean that i could buy the LCR ARB kit as the rear is the same as the LC i take it.
I'm pretty sure the subframes are the same part numbers so in theory the LCR front ARB would fit but as above if you are very low you might have other clashesJust to set my mind at ease lads. I have a leon cupra but have the Koni FSD's fitted which have the ARB mounting points on. So this would mean that i could buy the LCR ARB kit as the rear is the same as the LC i take it.
I have asked this before but do worry about making sure its right as dont want to order the kit drop the subframe and then find that its wrong.
Yea know a boy in VW aswell so will see what he comes back with price wise but should be 10-15% off. Think it will be a 23mm R32 then and then get the 25mm rear eibach. Cheers lads
The drop links are the same for the S3/TT/LCR. No real need to change these but it's an option if you want to blast the whole handling and not have to worry about anything again.Hey Willie, should i be fitting r32 front ones aswell then or the standard leon/golf ones. I know that they dont get as much of a beating as the rears. Also would you know if all the drop links will be the same? Cheers in advance.
PS i wonder if the complete r32 wishbone will fit as would be a much easier job to fit it with all the bushes pre installed. Normally only looking at £20 for a standard golf/leon fron wishbone with the bushes installed! going on the golf site for a bit of investigation into this one . see what i find.
