I carried out this operation at the weekend, with the assistance of my brother, and found it quite difficult.
the Hex end of the wishbone does not slide in quite as easily as described in the guide.
the wishbone can't be aligned properly until the hex end is through the Bush far enough to get the front bush into the final fitting position.
we persevered and with plenty of lubrication, the strap and assistance of a mallet and some , the wishbones eventually made it to the correct position.
The hammers I've been using is not very big, do you think a large lump hammer would be better? My car's been sat on my drive now since bloody Wednesday and I'm having to get lifts to work off my g/f!
I've tried the ratchet method on both sides, put loads of grease and tried washing up liquid on and it just won't go in. It gets to within about quarter of an inch until it reaches the end of the bush but won't go any further, have snapped the strap on the ratchet a few times and had to re-tie it to the metal!
Also, and this is stupid but I thought I might of been able to remove the cross member out the way to get it aligned better and undid the 5 (i think) bolts and removed them but when the last one came out, what ever was on the top of the bolts moved and the holes are out of line now! It's just going from bad to worse! Does anyone know what is behind it? To be honest, when I did that I just threw all my tools in the garage and went to the pub coz it was getting dark but going to have to get this sorted by tomorrow because that's when my MOT re-test is.
Someone please give me some hope!
PS - How accurate does the hex have to be aligned as in horizontal top and bottom when pressing the bush in the console? As obviously I was under the car and doing it by just using my eye's. It's pretty much straight but how perfect does this have to be? Just a thought. Will they evenentually twist into the correct position whilst driving or is this why you have to get the geometry done?
Thanks again.
