Mykies1.4 sport
Hey folks got a 2007 1.4 85bhp looking 4 sum ideas 2 get sum more power out of it. Has anyone done anything to theres and noticed a difference?
you can find out about a re-map..would give you most increase in power. air flow/induction kit will give you some extra bhp and a nice noise too...search the forum sure theres plenty of folk who have done some mods on a 1.4
I had an induction kit on before also got a little breather filter but it kept falling off letting oil 2 piss out evrywhere so had to put the original air box back on
wouldnt waste your money put it in a savings account and when youve got enough go and buy a pd130 or a 1.8t, 1.4 NA will never be fast.
It's a 1.4 n/a so big gains are near on impossible unless you pump serious money into it.
To keep things sensible, go for a decent exhaust system, spark plugs and pannel filter. Pannel filters for the 85 are rather hard to find as I previously ordered one via two different companies and I had the same issue so gave up in the end.
Apart from that, upgrading the suspension won't give you more power but will give you better handling effectively making you faster through the corners.
If you decide to go for the pannel filter, heres the one you need for the 85 1.4 engine:
http://www.knfilters.com/search/product.aspx?Prod=33-2920
Good luck
