Adjust brightness of interior lighting
Jun 20, 2024
20
I recently switched to LED bulbs for my interior lighting and everything is working without any faults. Only problem is that I find the bulbs a little too bright. Does anyone know if it’s possible to adjust their brightness with VCDS?
cairus
1,241
447
In the interior you can only adjust the brightness of the footwell and ambient lighting. If you mean make-up mirror light, ceiling light etc., it doesn't work
Reactions: ilovezed
mty12345
4,078
665
bristol
If you're handy with a soldering iron and you can see the circuit board, the you could swap the resistors for ones of a slighty higher value. Not sure if that would trigger a fault code or not, you'd have to experiement and see.
Reactions: ilovezed
Mr Pig
2,848
1,039
What's the point of fitting LED bulbs if you're just going to make them look like incandescent ones?
