I recently switched to LED bulbs for my interior lighting and everything is working without any faults. Only problem is that I find the bulbs a little too bright. Does anyone know if it’s possible to adjust their brightness with VCDS?
In the interior you can only adjust the brightness of the footwell and ambient lighting. If you mean make-up mirror light, ceiling light etc., it doesn't work
If you're handy with a soldering iron and you can see the circuit board, the you could swap the resistors for ones of a slighty higher value. Not sure if that would trigger a fault code or not, you'd have to experiement and see.
