Hi Guys,
I've already done a search but couldn't really find anyone with the same issue (plenty of revs rising when clutch dipped but not this).
The car holds revs and if i've pressed the pedal in quite far but stopped before the revs get high, when I dip the clutch the revs go very high. Also if I accelerate reasonably hard then let off the car will continue accelerating or at least hold it's speed, which has scared me a couple of times so far!!
When driving normally it's not so much of a problem as I just dip the clutch but whenever I change gear or come to a stop the engine is revving anywhere between 1500-2500 so makes me look like I cant drive properly! lol. If I put my foot under the pedal and lift it up there is a small amount of movement and the revs always settle back down to 800 as per the norm.
Now, in my head I imagine the spring (or whatever) inside the pedal has broke, or something inside has broke, so wondering what else may be wrong as I could do without spending £100+ for a new pedal right now!
Cheers.
Cheers.
