AC Fault - AC Compressor Not Engaging - Help Please
Priezti
Auto-Electrical Monkey!
Feb 11, 2009
119
Doncaster
if the air pressure switch needs changing is it a case of having to drain the a/c or does it have a valve etc so just replace as normal? anybody know ?
hugosantos
46
London
Hey guys I need help . my air conditioner does nothing, I have search here in this forum and other to get some tips and here's where I am at the moment.
Issue - Air conditioner does nothing no air nothing...
the climatronic looks to be fine , I can even hear the relays switching when pressing some buttons, and the fuses also are fine...
My blower is not stuck, I removed it and cleaned it ( it was fine just dusty) ... There is voltage reaching the blower but I do not know if the reason that It does not turn if its the clutch that a lot of people talk about ...
what can I do next ? I even done the test with Vag com but I do not understand most of it...
But here is the fault that appears on the Vag com :
18049- please check DTC MEMORY of A/C Controller
P1641-000
Freeze Frame:
RPM: 0/min
Torque: 118.0Nm
Speed: 0.0 km/h
Load: 0.0%
Voltage: 12.31v
Bin. Bits: 00001100
temperature :18.9Celcium
no units : 144.0
I have other faults like the P0672 Cylinder 1,2,4 glow plug circuit fault but will deal with that next
can you guys help?
hugosantos
46
London
Just Tested the blower today and it works Fine ( I plugged it in a 12v power supplier and it spined fine)
On the car there is also power reaching the plug ...
On the car plug that goes in to the blower there is 4 wire ( two cables are power and the other two I guess are the controll to activate it)
where do they go? im going to remove the climat control again and see if the cable go to the climatronic or not ( and then Ill check the continuity of the cables to see if they do reach)
any other advice?
SWANSWAY CUPRA Dealership
