ABS + TCS warning lights
speedsix
Leon Cupra R 225
Oct 30, 2004
825
Both on this morning, stopped the car, turned the ignition off then on, abs light remains but the tcs light went off.
Checked fault codes, listed o/s front sensor. Cleared the fault code, abs light went out when I started the car and remained off when driving for a bit. I'll keep an eye on it, any ideas why this happend?
Dom
Ruddmeister
Everything in Moderation
Jun 23, 2003
8,218
Weston-super-Mare
en.wikipedia.org
If it's anything like mine it comes of then goes off (sometimes TCS and ABS sometimes just ABS) I believe it to be a sensor fault and it comes on once a month ish.
Like you say turning the ignition on and off sometimes resets it.
What I sometimes get it ABS also kicking in when Manouvering in a carpark, particualrly if I have some lock on the steering and pull into a parking bay....very odd because I'm only doing walking pace type speeds :shrug:
Give the brakes and discs a good blast with a jet wash or power washer to see if it's just a bit of cr@p on the discs etc.
I assume it's a sensor on the way out :shrug:
speedsix
Leon Cupra R 225
Oct 30, 2004
825
I noticed yesterday the abs kicking in pulling up to a junction slowly, thought it was odd at the time. Let me guess abs sensors cost a fortune? :cry:
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
likely sensor and or connections to said... the amount of salt and corrosion at the mo is huge... :(
Munky
108
Northants
I had the same prob and just had a new sensor fitted.., sensor was £50 and the garage fitted it for £15...
