ABS & TCS light
DaNnY_LaD
Big Turbo Leon Cupra R
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
When i start my ibiza i get no light but soon as the boost comes in from -vac the abs and Tcs light come on...
the idle when it 1st starts seems strange and it went in to limp mode last night 5psi...for about 20mins even with turning it off and on then after the 20mins wen i was near home i had the lights still but then had full boost
goin to see if chris could get it vag-com'd today
Damoegan
Sir Bob,a geordy legend..
Oct 15, 2007
8,993
Newcastle
We are just guessing till you get it vag-com'ed,Danny.
I had the same light on when my MAF was shot though.
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
but those 2 lights come on with many many codes.
I had this when a fuse blew (the red one in second row iirc, i made a thread on it with pics) I was also running limp and had both lights on.
All i am trying to say is that we will not be able to point you in the right direction without guessing
Damoegan
Oct 15, 2007
8,993
Newcastle
Yea, thats why I said "We are just guessing till you get it vag-com'ed".
We could be here all day guessing, and thats all we will be doing, guessing.
ChrisCurzon
4WD FTW
Apr 9, 2006
1,821
Bolton
Just read the fault codes on Dannys car and these came up
8 Faults Found:
16622 - Manifold Pressure / Boost Sensor (G31): Signal too High
P0238 - 35-10 - - - Intermittent
17952 - Angle Sensor 1 for Throttle Actuator (G187): Signal too Large
P1544 - 35-10 - - - Intermittent
17580 - Angle Sensor 2 for Throttle Actuator (G188) Signal too Low
P1172 - 35-10 - - - Intermittent
16496 - Intake Air Temp. Sensor (G42): Signal too Low
P0112 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-10 - - - Intermittent
16795 - Secondary Air Injection System: Incorrect Flow Detected
P0411 - 35-00 - -
17963 - Charge Pressure: Maximum Limit Exceeded
P1555 - 35-10 - - - Intermittent
Once we cleared them we went for a drive and the ABS and TC light came back on, but no fault codes appeared when we plugged it back in
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Yeah and some of the Codes are when i was fitting new ECU,injectors and when i popped a hose of i had to unplug my maf to get me home...
So kinda usless...
As soon as i start Rolling and drive the light come on but if i turn it on and rev it ect no lights
Rick1.8t
150
My ABS and TCS lights came on not so long ago.
No limp mode or problems though with the running, no vagcom codes either - i dont have any ABS or TCS though (which made the snow interesting)
Im guessing i have a dodgy abs sensor or wire - ill have a look soon, it may be that?
Rick
-pseudonymous-
681
Before you go replacing anything Danny just check your fuses as Reuvers said. Most likely the red number 8 10amp fuse. Then clear the codes afterwards if it has blown.
ian_cupra
abs sensor, i know thats what mine is, as needed a new hub, got one really cheap and quick, and doesnt have the asb sensor parts on it, so both tc and abs lights are on now
