ABS Pump 1K0614517AF
Jasonsmith1989
34
I've just purchased this from Ebay (link) to replace my ABS pump with a faulty pressure sensor. You only get the hydraulic pump, not the motor or the ecu module. I'm now just a bit worried that my ABS is not one with a detachable motor as I've seen some where the pump and motor are one unit. Is anyone able to tell me if I have the correct part from my part number? Due to have to fitted on Friday.
Rusty2k
713
137
Should be fine as long as your mechanic is competent enough to dismantle and resemble the ABS unit.
Jasonsmith1989
34
Thanks for the info, he should be it only looks like a couple of bolts holding the motor onto the unit unless I'm missing something.
Rusty2k
713
137
The hydraulic block complete with the pump is a couple of bolts yes, but I don't know how the pump is retained. It might come off with just those 2 bolts or there might be more securing it from the underside of the block. I've not taken a unit apart so I can't say for sure. I can't imagine it's too difficult though. Maybe ask the eBay seller what steps are required?
ATE have a video on doing the repair with the genuine repair kit that gives an idea, but that kit includes a new pump so it doesn't show the removal of that.
The captions are in Italian but the narration is in English
