to add (sorry for long post) the car is running perfect. Its boosting to 0.6 bar and I'm not noticing anything weird...
The ECU on rhd cars is on the left hand side where you said when looking at the car. Might be on the other side for you as its lhd. You'll know what it is when you see it as it has the part number on it ad two plugs going into the front. ECU might be wet on the inside but now be dry on the outside. Realign the throttle body to rule it out and replace the abs sensor cable then see what happens.
