Update on this with which I'm hoping to get some
help
I now re-insulated pretty much half of the ABS wiring.
I then deleted the 00285 code again (ABS fault right front)
The lights were both off from then on and the ABS no longer kicks in when it shouldn't. Furthermore TCS is working when it should as well, and if I'm correct, ECT will only work when ABS is properly working and visa versa...
However a day later the TCS light came on along with the EPC light. Not the ABS light this time.
I read the codes and it was
18048/P1640/005696 - Internal Control Module: EEPROM Error
Possible Causes
Engine Control Module modified (e.g. Chip Tuning)
Engine Control Module faulty
Possible Solutions
Contact your Tuner
Replace Engine Control Module
Retrieved from "http://wiki.ross-tech.com/index.php/18048/P1640/005696"
and
17953/P1545/005445 - Throttle Valve Controller: Malfunction
Possible Symptoms
Increased Idle Speed
Bucking at Load Change
Possible Causes
Throttle Body dirty
Throttle Body Wiring faulty
Throttle Body faulty
Possible Solutions
Clean Throttle Body
Check Throttle Body Wiring
Check Throttle Body
Special Notes
Use Meas. Blocks & Basic Setting for testing
Retrieved from "http://wiki.ross-tech.com/index.php/17953/P1545/005445"
The Eeprom error I have had before, and just had a look at what I think was the ECU (under plastic cover by window wiper arm? where the 2 plugs go in from front??)
it wasn't wet there...maybe slightly moist...
As for the throttle, could this have to do with allignment, as I took it off about 1.5 months ago, and don't have full vagcom to reset it?
any
help is much appreciated
