Abs and traction control light
jakesmith89
abs and traction controll light have come on anyone no what this could be
jakesmith89
its all good now they have just gone off. i need new brakes do u think this is what it cud of bin
Jun 17, 2007
1,032
Aberdeenshire
They will do that periodically for a while but you will have a knackered sensor somewhere.
try getting them off in oone piece i mean try and give them a clean and see if that works. Not being funny but do you have ABS just now?
cupramillo
The "Red Baron"
Feb 24, 2008
2,039
South London
My ABS/TCS lights are on, scanned it with VAG com and it was a front wheel speed sensor. Ordered one for £25, job done, just need good weather to get it fitted!
Turbo Joe
Its probs just the time of year bits of grit and stuff getting into ur sensor then getting washed off again mine has done it a few times wait till better weather and c whats what from there
devonshirejock8
I just bought a new maf and abs sensors because i read this forum about the traction controll light.I have now fitted both and still light is on any other ideas??????????????????????????????????????????????? :(
Aug 22, 2011
557
aberdeen
use a code reader (£20 off fleebay) and scan your engine and ABS control modules.
I just had this problem on mine. No engine fault codes but fault code on BAS says front left abs sensor faulty. I have replaced this and all is good no more lights.
The best tool you can have for these style cars is A code reader the best being VAGcom/vcds.
devonshirejock8
problem sorted now stuck it in for mot and the sorted it ma calipers were sticking the garage striped and cleaned them whalla no more lights
