so 4 months ago i fitted the said 16v lump into my mk2 golf. using the digi 3.2 full management. the only sensors i didnt use were the charcoal evap and gearbox sensor for the speed readout (im using my existing 020 with cable drive). these errors obviously show up through vag-com.
the install went perfectly, in in a weekend, and 4 months of perfect, quick driving
until one night i got a terrible idle. iv a solid mount (as the idle was perfect before. very smooth). it really shakes the car around.
it also hesitated badly and would not pull. i think iv put the hesitation down to a very loose p/s bracket. only 1 bolt. since it re-torqued it the hesitation has gone. i think it was knocking and the knock sensors saw this and pulled the timing back.
so, the idle. start the car, and its perfect (ish). then it'll get rougher and rougher. really shakes the car around. drive up the road 100m, pull over. and it'll idle as it should. problem gone. well, not as it should. im sure even at its best it doesnt idle lke it used to. it does it warm or cold too. its intermittant. if its idling rough, if i turn off the ignition and restart, it'll idle perfect again. hmm
when i did the car, all parts were new. cam belt and ignition parts. all from tps vw. iv cleaned up all the earths and contact points. i suspected the coil, but after checking a few others, and resistance through autodata, its perfect. so is the isv. new vw relays (ecu+fuel pump). all new vacume hoses too.
no fault codes are showing through vag-com, im lost!
any ideas chaps? iv got a spare tb, crank sensor and dizzy and leads to try next week.
annoying as i was ready to get the head done, aswell as mapped. i wanted to make sure everything was sorted and correct before i started tuning.
btw it seemed healthy just before the idle started. dyno_dynamics machine read 149.5hp and 139lbft
cheers in advance guys
Paul
Paul
