mat564
my lcr smokes a little when just ticking over not a lot but i have noticed it it doesn,t blow smoke out when im driving is this normal or do i need a trip to dealer regards mat
white or very light grey its not black anyway
im no expert but id say the result pretty much cancels internal engine problems.
i'm on my phone an hard to do pm as my phone is crap. Will do later. Going to look for hose under inlet manifold as been told prone to blocking. Cant see how the smoke is not making plugs black but coming out exhaust blue. When initially start car its ok for a min. When been driving for a while an pull up if rev engine get lots of smoke. Really confusing me
it passed mot last week. Why wouldn't it rule out head gasket as if was headgasket would have oil in coolant an the smoke wouldn't be blue it would be white i though. Also when doing compression test if was leak beetween 2 cylinders i would have lost compression. All the readings were good.Just for some info, compression checks don't rule out valve stem seals or head gasket problems, you can get a head gasket sniffer or go to your local MOT place and ask them to monitor for exhaust gases in the coolant.
