Just over the last few weeks I’ve realised my A/C is stone cold on the right most vent, then the temperature as you move across the other 3 towards the far left gets warmer and warmer to the point I think there’s no cooling at all most left. I’ve done a good amount of googling with little luck, so any advice would be helpful.
May or may not be relevant - car got a new heater matrix 1+ years ago, not sure if it’s all bled properly as you can sometimes hear gurgling under the dash when the car is switched off (is this involved in the cooling side?), heating seems to be fairly consistent across vents.
Thanks!
Thanks!
