A/C fault?
Phil Gee
56
Naughty North!
Got in my Leon this morning to defrost the car and my A/C function wouldnt switch on. Its the type with the big screen with climate control. The symbol would appear on screen for a brief second then switch off. Everything else works fine but no A/C.
I'm guessing theres a fault but could it be an overide function for when its too bloody cold? Is there a fault mode a can carry out on these climate contol setups?
Any help is muchly appriciated. Phil .
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
It doesn't work at temperatures less than +5 centigrade.
ChrisUK
Eat My Smoke
Oct 20, 2004
2,258
Liverpool, UK
Mine was on too this morning at 2 deg
When you hit the button to blast the front windscreen, there is a little snowflake on the display (which I promptly turned off lol)
edmong
GHE Tuning
Aug 15, 2007
567
Plymouth, Devon
Same prob happened to me. Mine was an abient temperature fault which is located in the bumper on mine (LCR 225 2005). The readings for the outside temp where reading anything between -45 degrees and +40 degrees. If you have VAGCOM you should be able to reset it but you will have to eventually cange the sensor.
Phil Gee
56
Naughty North!
Thats pants! What if you want the A/C to work when its colder than that outside? Just checked and outside temp is 8.5 and its working now!
cuprascot
Just signed up to ask you guys about this.Very same happened to mine this morning everything fine apart from a/c not coming on.
NickT
429
LB, Beds
It's a design feature to protect the system at freezing or close to freezing temperatures, I guess some components (compressor?) could be damaged if it tries to operate at these temps.
As R6_allan pointed out earlier it's in the owners handbook.
