Hi all
Well i had the engine light come on this morning so ran a Full Scan on VCDS
It came up with the codes below and on checking a 10 amp fuse was blown .
Replaced thr fuse and it blew within a mile of driving after clearing the codes which also returned,
As all the code relate to that fuse which is fuse 7 i think, i suspect ive a break in the wiring harness somewhere.
Anyone ever had this or similar array of codes ?
Any areas to look at maybe that are common areas for the harness to chaff ?
13871 - Coolant Pump for Intercooler
P023B 00 [039] - Short to GND
17971 - Heater Support Pump
P16BF 00 [039] - Short to GND
10385 - Coolant Valve for Cylinder Head
P199D 00 [167] - Short to GND
9490 - Oil Pressure Regulator
P165F 00 [039} - Short to GND
10385 Thermostat for Cylinder Head
P199D 00 - Sort To GND
