martin16v
Good morning all, PLEASE HELP!!! i have purchased a Seat Ibiza 1997 2.0 8v Gti (agg) however.... the previous owner has put a MK2 Golf 8v Gearbox onto it!! the two problems are..... Firstly! you cannot select reverse! if you disconnect the linkage then you can select reverse easily at the gearbox! but when you re-connect the linkage and try reverse it goes into 1st !! i have tried and tried to re-align but to no avail!! Secondly.... the clutch pedal is really low! the pedal is only about 2" off the floor?? Any help would be really appreciated!! Thanks guys.
