8v GTI 1997 with Golf Mk2 gearbox
martin16v
Good morning all, PLEASE HELP!!! i have purchased a Seat Ibiza 1997 2.0 8v Gti (agg) however.... the previous owner has put a MK2 Golf 8v Gearbox onto it!! the two problems are..... Firstly! you cannot select reverse! if you disconnect the linkage then you can select reverse easily at the gearbox! but when you re-connect the linkage and try reverse it goes into 1st !! i have tried and tried to re-align but to no avail!! Secondly.... the clutch pedal is really low! the pedal is only about 2" off the floor?? Any help would be really appreciated!! Thanks guys.
CraigW
Craig.
Apr 12, 2007
4,607
Hawick, Scottish Borders, Scotland
The clutch pedal being really low is an easy one, pedal box has gone.
Search the forum for it theres loads of information about it.
martin16v
can anyone tell me if they have fitted a standard MK2 golf 8v gearbox into there Ibiza Gti ?? if so did u have any problems with the gear linkage ?? Thanks chaps
Dolly_Gti
G60 spooling up.
Aug 15, 2006
1,412
china town
the 8v box's, O2Os should all fit each other, you might have a problem with the gear shift unit its self, pull the leather gaitor up and have a look at it, i have a unit which had a broken part and funnily enough it wouldnt select reverse.
pedal low may just be a clutch or cable, but i certainly wouldnt rule out the pedal box.
Dave_R
Save a Sheep...Buy Brembo
Sep 20, 2004
3,666
South Wales
Sorry to go off topic, I'm in a odd mood today so please forgive me :)
Why is your name martin16v and you drive a 8v?? :D
And back on topic, "Chrisdaman" fitted a Mk2 Golf 8v box to his 16v and had to change the clutch because it's got smaller splines. Could be something else to look at.
Dolly_Gti
G60 spooling up.
Aug 15, 2006
1,412
china town
wish i had an 8v box on my 16v, rod change feels alot better and gave more reassurance when really throwing it through the gears.
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
less likely to hold on tight when ya in the zone too - cable can be annoying
Linkian
neva want the ride to end
Sep 11, 2007
92
Portsmouth
woah woah im confused i thought a mkII Ibiza is a mkIII golf, cant remember exactly how i came to this so if im wrong dont make fun just comment.
martin16v
Well thanks for all your info chaps, My nickmane 'martin16v' was from my MK2 golf days, used to have a real nice mk2 Golf 16v, i still have a pristene mk2 Golf 8v too lol, Well from the reciepts i have with the car i can see that the correct clutch was fitted, also it selects all 5 forward gears easily! just the reverse that is being a pain in the ar*e !! i am bringing the car home next week so will have another play, I will keep you all posted! Thanks again chaps !!!
Dolly_Gti
G60 spooling up.
Aug 15, 2006
1,412
china town
lift the gaitor up, i cant remember what it was but something had snapped at the foot of the selector, it was pretty obvious when i saw it. it would push downward but the broken part stopped it going across the gate.
