Managed to get a good few hours of car stuff in at the weekend
Spent Saturday afternoon doing a few jobs.
Got the EGT sensor changed finally, what a ball-ache that was. Tried to do it from above, removed the turbo outlet, charge pipe, DV and a few other hoses but still couldn't get in down behind the engine to get a spanner on to the probe bolt on the turbine housing. Ended up going under the car again, managed to get a 17mm spanner on it and got the old one out. Couldn't get the thing back up out of the bay as I couldn't see where it went in under the coolant pipes above the turbo compressor inlet so ended up losing it and cutting the old cable.
That was fine but meant I ended up routing the cable for the new one a little bit differently but it should be OK. Job done anyway and my MPG is back up to normal sort of levels again, plus the idle feels smooth again too.
Also got my summer wheels cleaned and back on the car. After washing:
Randomly picked up some Simoniz 2-in-1 alloy wheel and sealant stuff in Halfrauds when I was in for some MF cloths a while ago so gave that a shot, came up OK and after a hoon on Sunday there was no visible brake dust, even on the fronts where the DS2500s are. Will get some proper cleaner and sealant for next time.
So on Sunday had a good hoon around Deeside, it's like one big playground really - anyone that hasn't been up here, get it sorted and come for a bit of a drive
For those that know the area, went out North Deeside, got to Ballater then came back along South Deeside but all of the above were full of sunday drivers so turned off at Aboyne and went from there to Tarland then back to Aberdeen through Echt, and that lot was a different story
Can really feel the difference in the Vredesteins over the winter Uniroyals, much more confidence pushing hard into and out of corners.
Got back home with several hours of sunshine left and Scarlett caked in road dust so broke out the buckets and hose. Just a very quick 2 bucket method wash and a once-over with Meguiar's Quik Detail spray but looks not too bad for the relatively little effort I put in:
Still on the to-do list - change R badges again, replace rear brake calipers, tidy the Brembos up a bit, get a couple of small dents pulled out, proper wash/clay/polish/wax. Won't be long before the timing belt, water pump and tensioners need doing again too, considering doing that myself...
