60mm or 40mm That is the question?
Mckellar
if you can get 50mm kits for it then id go for that although you will get slight rubbing on turning sharply, and if you carry people in the back.
i had my 1.4 lowered 70mm roughly on the front with 15s and it didnt rub at all..just your luck, good thing about coilovers is you can adjust it if its too low/too high etc..
Czechboy
Tarmac terrorist
Apr 14, 2005
1,607
Hampshire
Rich, tell him to get coilovers ;). If you are lowering 60mm, you will need to cut the driveshaft balancing weight, grind down some of the front arch plastic liner, and possibly grind away some of the back arch.
Put simply, 40mm is a more reasonable for a daily driver. For reference mine is -55mm, but is on 16's and not 17's.
Mig
sionowz
230
cardiff
I've dropped mine 60mm with 17's on... thats all I've had to do is trim the inner lip of the arch (because my wheels are et45) and modify some of the arch lining...but it does rub slighly on full lock. plus i've only got 2 seats so I dont know what it would be like with a full car.:blink:
Mckellar
Mig
*****, get them down mig!! :whistle:
Czechboy
Tarmac terrorist
Apr 14, 2005
1,607
Hampshire
I tried mate, but it wont go :cry: . Not even another -5mm. Because then the middle of my tyre scrubs on a random mould in the arch liner. The outside of the tyre scrubs on the arch when the wheel is turned any more then 45 degrees. And the back makes a dodgy knocking noise.
Also my car only JUST makes it out of my Uni multi story car park. Honestly you couldn't fit a silver Rizzla into the gap between my splitter and the ground :lol: . Will have to take a pic one day.
Mig
Mckellar
no bother then i might let u off then lol...
u remind me of a picture i took of my old ibiza..
how i miss the lowness:
Mckellar
until he winds them all the way down and realises his ride is too soft in the quest for being low.
i feel your pain! when mines was on its hole it was soft as cow sh1te, useless if you want good cornering! its called a sacrafice to fashion :lol:
might aswell of put it on a trailer then :p
hydraulics/airbag suspension are the route of ultimate slammed to the floor, but no idea what the ride is like?
£1400 airbag suspension fitted from rayvern but there is a 3month waiting list to get booked in. :blink:
