Ok. I have a leon cupra, i reset everything (disconnected the battery) drove it for a couple of days and did a diagnostics check and found the following 5 error codes
17545 P1137 Long Term Fuel Trim Add.Fuel,Bank1 System too Rich
17769 P1361 Cyl. 3, ignition circuit Open Circuit
17772 P1364 Cyl. 4 ignition circuit Open Circuit
17705 P1297 Connection turbocharger - throttle valve pressure hose
18010 P1602 Power Supply (B+) Terminal 30 Low Voltage
how do i rectify these problems? and possible prices on parts if applicable? cheers
