4 digit ECU pin to 7 digit ECU pin
RJ
im a bit lost in coding a replacement ECU on MK1 Seat Leon 1.6 SE , have used vag-tacho to retrieve the ecu pin that is 02435 , my understanding is that
Example found on icc-immo help page
08618 - 4 digit code,
01742 - dealer no,
444 - importer code,
150307 - date of issue (15 march 2007)
this creates 08618-01742-444-150307" that when 'calculated' created a 7 pin code ,
( i have my 4 digit code , dealer no , importer code and the date of issue )
i need a 7 pin code to use VAS 5054 to connect to 'geko' and then code the cluster and keys to the ECU , :shrug: buttt ive searched around and cannot find software except icc-immo software that i cannot download or make contact with supplier , is there another way , any help much appropriated
Thankyou
RJ
Update : have successfully coded a separate ECU from a MK4 Golf 1.6 as the code was retrievable as original clocks were attached ,
so its runs, badly as many ecu faults as it isnt the same part number ,
next question is , is there any way to copy immob information from one ecu to another :D ,
MJ
5,547
33
Manchester
You can via immo dump but you'll need the hardware and software to do so.
How did you pair the ecu in the end? Using VCDS? And why was a replacement needed?
RJ
we got the car from ebay as a non runner with an immob fault ( classic story that mrs got in car and wouldn't start etc ) ,
got it home and VAS said it had a mk4 golf VIN stored [:@], but the part number was for Leon and Toledo only ( ending in CP ) highly confusing ,
in the end we got a ECU from a golf mk4 1.6 from scrap yard that was immob3 and did a cluster read before removing it to reveal the ecu code using vag-tacho ,
we then used this ecu to code the seat's cluster and keys using VCDS to the car started but run extremely poorly it was hunting etc ( DTC engine temp and throttle position fault ), as well as a few others
next step was to open both ecu , remove the immob chip from the coded Vw golf ecu and solder it in the original ecu , ( the ecu immob chip had been removed maybe previously as had some cleaning marks etc surrounding it
:clap: andd it works perfectly and runs spot on
no need for 7 pin skc in the end as used vag-com not VAS :)
if anyone did need this software to convert a 4 pin SKC to a 7 pin SKC i found at this download link :
(note : had a little play with this and it made some 7 skc's , but it also made weird 6 and 5's depending on date , as i didn't need this pin in the end i haven't tested the 7 SKC produced it actually works with VAS )
http://www.auto-professionals.co.uk/attachment.php?aid=5961
