Post the link in here,
I got mine from Ebay for about £80, If I had a choice again however I'd go for the 20mm Hubcentric B+ FK spacers. They might be slightly more expensive (About £100) but their safer and more lightweight and the lighter they are the less stress your putting on your wheel bearings
Not that anyone here has had wheel bearing related issues, better to be safe than sorry though!
I hate to say this, but no1 anywhere has ever had wheel bearing issues from spacers. Its a common misconception thats bandied about of internet forums.
If anyone can give me a logical explanation why it would cause premature bearing failure from an engineering point of view, I'll eat my rear spacers
.... *facepalm*
To be fair, over the rear wheels 25mm and below its doubtful you will ever encounter wheel bearing issues. Front spacers on the other hand are a totally different matter, Theres nothing banded around by anyone.
Extending the wheel past standard width will put more stress on the components that hold the wheel in place (Namely the wheel bearing) The wider you go the more stress you'll place on those components because your widening the pivot the whole car sits on.
I cant provide you with pictorial evidence as... well I dont put them on the front.
Imagine taking a ruler placing half of it off the end of your desk. put some weights on it. now move it further and further off the desk now jolt it up and down, That pivot is your bearing, after a while it will fail!
So, What your telling me is that no load is placed in wheel bearings.
Infact... No damage can be done to wheel bearings by placing large spacers on cars where the weight is located?
I better reconsider vertical vs axial loads
"the horizonal lateral distance from the center of the wheel bearings to the center of the wheel patch multiplied by the weight supported by the wheel is equal to the bending force on the bearings, technically called moment.
An ideal configuration has the bearings right over the wheel patch... the horizontal distance = 0 and there is no moment on the bearing group. Add a spacer, however, and there is a moment which, in turn, puts lateral stress on the bearings. To be honest, I don't think a 10 mm spacer will cause much harm either, but it is introducing stresses outside of the originally envisioned design stresses."
I'm not saying DONT use wheel spacers, ****, I use 25mm rear spacers and was going to use 15mm wheel spacers.
But to say they "but no1 anywhere has ever had wheel bearing issues from spacers" is absolute horseshit
Its like saying that remapping your car wont put extra stress on your turbo
do you know anywhere to get these at a decent price? i only want rear wheel spacers because people on here say they make a nice difference to the handling.
i dont like the idea of going with heavy spacers although they probally dont make much difference to the lightweight spacers apart from weight.
